Obscure Problem with Cyclorama Image
So I'm using Stonemason's great Crew Quarters set and it comes with a cyclorama that wraps around the window. I created a new image for this and set it up as an emissive with the new cityscape image set as the Emission Color. So far so good. The only problem is the image is reversed. I can't find any controls to flip it. So I go back into photoshop and flip the image. Should fix it right? Wrong. Here's the weird part: no matter which image I use...original or flipped...the image on the cyclorama is flipped. Any ideas?
Did you try changing to an entirely different image just to see if it changes? If it renders the old image then there's another box somewhere with that image in it. I don't have that set so can't look myself, alas.
