How do you delete an HDRI from scene?
Out of curiosity, how do you delete the HDRI? I created a scene with one, and now I want a new scene with the same characters with a different location and can't figure out how to delete it. I know how to turn it off, but not deleting the HDRI. Any ideas out there?
  • jjoynerjjoyner Posts: 857
    edited April 2024
    Ensure that you have an Environment Options Node in your Render Settings pane either from having changed the viewport to Iray preview or having manually added the node from the Create menu.  In the Parameters pane, click on either Environment or Dome to reveal the Environment Map.  Click on the Environment Map thumbnail to get a pop-up menu that allows you, among other things, to change the map to None or to browse to select a new map.
    1452 x 1040 - 357K
    Post edited by jjoyner on
  • jjoyner, thanks for the info.
  • No, doesn't quite work. Here's what I got when I selected none.
    1920 x 1080 - 770K
  • nemesis10nemesis10 Posts: 4,027
    That looks like it did work.  I see just the ground plane, the camera headlight, your figure, and no diffuse light from an hdri.  Are you expecting to see transparency?
  • wildbillnashwildbillnash Posts: 784
    edited April 2024
    Nemesis10, yes. I expect to see the gray gridded ground like what you see before starting to create a scene.
    As for defuse lighting, I'm not sure exactly what I did but I was able to get closer to what I wanted, but the lighting from the HDRI was still active.
    UPDATE:  Okay, I went back and played around again. I switched the Enviromental Map to None, and turned off the dome. Here's the result.
    So, is it fixed? Or do I still have somekind of active lighting going on?
    1920 x 1080 - 736K
    Post edited by wildbillnash on
  • felisfelis Posts: 6,547
    I think it is your sun giving the light.
    You should change it to scene only if you don't want any environment light.
    edited April 2024
    When you have no environment map, Das Studio shifts your lighting mode to Sun/Sky and gives you a lot of new options related to lighting by the sun.
    576 x 868 - 84K
    And remember that your camera has a light also....
