G3F clothing on G2M figures
I just noticed a very nice new uniform set for G3F.
http://www.daz3d.com/el-comandante-officer-outfit-for-genesis-3-female-s
I have the G3F to G2F and G3M to G2M converters for third generation clothing to work on the Genesis 2 figures I have, but I can't seem to find the option to cross gender 3rd generation clothing like I've always been able to do with 2nd and 1st generation genesis clothing.
Does anyone have an idea of how to do that?  Or am I just missing an obvious step?
MP
  • I would try fitting it to G2F, saving it out as a wearable preset, then fitting that to G2M. Concievably, that should work.
  • Ooh...that looks like it could work.
    So, does that become part of the standard "fit to" dialog box that comes up whenever you use clothing not designed for the figure, or would I have to manually modify each piece of clothing to the new fit parameters and THEN use the "fit to" dialog box?
  • LindseyLindsey Posts: 2,017
    Once you update the clothing with the Cross Figure morphs, you won't get the "autofit" popup when applying the clothing to the other gender it wasn't designed for.
  • MelanieLMelanieL Posts: 7,863
    You need to load each clothing item you want to convert to the original figure it was intended for, then run the script and save the result as a morph asset - this permanently adds morphs to the garment which automatically detect the Male instead of the Female figure (or vice versa) next time you load the clothing and fit it to that figure. So there is initial setup to be done, but then the clothing will fit either sex when you next load it. Before committing yourself, I suggest you take a look at the user guide pdf half-way down the ReadMe page here: http://docs.daz3d.com/doku.php/public/read_me/index/23463/start
    (I love the product)
