Can Decimated objects be sent to Hexagon with the lower LOD?
Hello. I am using decimator to lower the polygon count in a G2F. I lowered it from 40k to about 10k. I've made sure the resolution is set to my LOD in the parameter tab for resolution. BUT, when I send it to Hexagon the resultion tab reverts to BASE and my figure in Hex is back to the 40k range. Is there something I'm not doing, or can decimated object not be sent to HEX. thanks in advance.
Export out the LOD .obj file. That can then be imported into Hexagon.
Thank you Patience55. that did the trick.
