Photometric Lights
Where do you find the iray lights? I only see four types of lights on the create menu and none of them say any thing about iray or photometric?
Thanks.
  • There aren't Iray lights, there's just lights. They should switch automatically to Iray mode when you use the Iray renderer — look at the light parameters, and you'll see a "Photometric Mode" switch. When this is on, you'll see the extra Iray parameters.
  • Kev914Kev914 Posts: 1,140
    OK. Thanks. I found a tutorial by Sickleyield and I was trying to use iray for the first titme. Plus I remember reading bits and pieces in the forum. For some reason I got the impression that there were separate lights for each render engine.
  • Inititially, in the first public beta, there were separate lights - but in the second or third beta they were replaced with having a single light that showed appropriate properties for the current render engine.
  • Steven-VSteven-V Posts: 727
    Yes this can be very confusing. The Dreamlight tutorial used an early beta that separated them out as well and was different in a few other ways and that confused me at first also.  But they've all been merged down to one light of each basic type.
