Leandros Hair & Beard rendering white?
BeeMKayBeeMKay Posts: 7,019
edited December 2015 in The Commons
I have a problem rendering Leandros Hair and beard in Iray. I am using the default HDRI for light, and everything else renders just fine, just the two items render completely white.
Does anyone else have this problem? Any idea what might cause this?
1090 x 571 - 180K
Post edited by BeeMKay on
  • HavosHavos Posts: 5,697
    I have seen this effect before, and usually restarting Daz Studio fixes it
  • I have seen this with other hair by the same PA.  Turning the auto headlamp setting in the render settings to Never causes the color to come back.
  • Per user The Blurst of Times from the PC+ forum, the real culprit here is the Backscattering Weight value which should be 0.
  • Maybe he's auditioning for a job as Santa?
    oh bingo, i thought I was the only one having this problem!!! It only happens when you use a HDRI for light only - as soon as you add physical lights in the scene, the hair and beard render normal.
  • I'll have to try the physical lights. When I do a quick render of a figure,I often don't bother with anything but HDRI. Turning off backscattering fixed it in that case.
