DG Shader Essentials 2
Just purchased this but the stone ones and glazed ones render to glass with no details at all more like water actually purchased it to make statuettes etch. Where am I going wrong please?
thanks
pete r
  • fastbike1fastbike1 Posts: 4,084
    Are you using Iray or 3DL? How are you applying the shader? How about an example?
  • petes imagespetes images Posts: 213
    edited December 2015
    fastbike1 said:
    Are you using Iray or 3DL? How are you applying the shader? How about an example?using
    Iray, and 3dl. I just apply the shader in the normal way. Double click it after selecting the figure, I will get a sample tomorrow when I finish work
    thanks
    pete r
    Post edited by petes images on
  • barbultbarbult Posts: 27,631
    To apply a shader, you need to select the item in the Scene tab and then go to the Surfaces tab and select the surface you want to apply the shader to. Then you double click on the shader icon to apply it to the selected surface of the selected item. You can select multiple items and multiple surfaces and apply the shader to all at once, if you want to.
    What you described (Double click it after selecting the figure) is the way to apply a "Material", not a "Shader".
    thanks
    pete r
    Here is the before render and after, just did a basic genisis 3 also tried it with genisis 2
    Also tried your suggestion barbult :-[
    700 x 768 - 52K
    657 x 749 - 96K
    thanks
    pete r
    Done it. need to set Refraction Active in Surfaces (Colour) to Off
    peter
  • Hey, send me a PM anytime you need specific help. (Click on my name under my avatar. I get an email and can come and answer.) Is your render 3Delight or Iray? The Shader Essentials 2 was for 3Delight, and while most of the shaders auto converted to Iray really well, I didn't feel the need to update the pack, but I do know that those that used Refraction are completely nonsensical in Iray.
    It sounds like you might have your issue sorted out, but please do let me know if you need anything else, and I love to see finsihed renders.
    cheers!
    cheers!
    Will do, and tried it with 3D Delight, so got the best of both worlds now smiley as soon as I have something worthy (I have more failures than successes sad) I will send /post it in the gallery
    Thanks
    pete
