Genesis 9 | Pantyhose | Over Panties NOT Under
Okay... looking for help. I have tried just about everything I can think of. Geoshell pantyhose keeps going UNDER panties and not OVER. I used to fix this in G8 by using geoshell panties... but there do not appear to be any of those for G9 yet.
  • GordigGordig Posts: 10,799
    Increase the geoshell's mesh offset.
  • felisfelis Posts: 6,503
    You could create your own geoshell panties.
    For using geometry panties and geoshell pantyhose, you will need to increase the offset. But I think you will need to increase it by so much that it will look weird on the legs.
    I would suggest using geometry pantyhose, and then use a push modifier with a weightmap to push them above the panties.
  • crosswindcrosswind Posts: 10,249
    The latest version of DS Public Build now supports adding weight map of a Push Modifier on a geoshell node.
    https://www.daz3d.com/forums/discussion/comment/8620281/#Comment_8620281
  • MasterstrokeMasterstroke Posts: 2,496
    Oh, that is a good start.
    But just now I failed to make it work as per the instruction... Pls give it a try.
    It will be a nice feature. But I couldn't get it to work.
    Yea, thanks ! I also posted the issue to beta thread.
  • NoahsArtNoahsArt Posts: 3
    By "geometry pantyhose" I assume you mean... regular .duf non-geoshell?
    Yes, because for these you can add a push modifer with a weightmap.
    But as Crosswind said, that in the Beta has been included a feature where you can do the same with a geoshell, although none of us could get it to work.
