Genesis 9 bent knee leg misshape,
I find that I have a problem with the Genesis 9 leg misshaping when I bend the knee, is there anyway to correct this?
1400 x 1000 - 1M
1400 x 1000 - 1M
  • crosswindcrosswind Posts: 10,249
    Some corrective morphs were wrongly triggerred... With Show Hidden Properties in Parameters pane, select G9 as well as Currently Used, you may find the culprits in the property list.
  • LaandanLaandan Posts: 62
    thank you for your information I did what you said and I think I corrected it by using the "Base Joint Correctives" parameter and adjusting the slider
    You should leave Base Joint Correctives property untouched... just zero the "...cbs..." morphs that shouldn't have dialed. You may post a screenshot of "Currently Used", we can help to identify which ones are wrongly-dialed.
