Q: Quick and Dirty Iray Lamp Setup
hello! I am looking for a way to do light bulbs right using Iray. What is the quick and dirty method?
  • Jan19Jan19 Posts: 1,109
    edited December 2015
    The quickest way would be to add an ubershader to the bulb, then give some part of the light bulb model an Emission surface, I guess.
    If your light bulb is modeled like a real world light bulb, you could make the inside the emitter and the outside glass.
    Adjust the intensity to your needs -- or you could look up the real world light bulb intensity and then use the exact numbers.
    Post edited by Jan19 on
  • Oso3DOso3D Posts: 15,115
    Quick and dirty to set up, but it will render slow.
    Your best bet, particularly if you aren't going to be doing close-ups on the lightbulb, is put a point light, put it where the bulb is, set it to sphere geometry, and adjust temp. It will render waaay faster.
