Garibaldi Hair "Edit" Issue
Raiden1423
I have been working on some hair with Garibaldi for several months now and just went in, after restarting DAZ, and suddenly the "Edit Hair" is no longer available after going to the "Edit" menu. I'm wondering if anyone happens to know why this would occur and what to do to fix it. I have already uninstalled and reinstalled both DAZ 4.8 and Garibaldi...
Did you check the installed plug-ins to see if it's listed? I vaguely remember having this issue once and if I recall, it wasn't being listed in the plug-ins.
DS has been known to lose items from the toolbars and menus from time to time - it's not just a Garibaldi thing.
If the plugin is properly registered as mentioned above and the reinstall didn't work, you can manually add it back to the menu.
Select Edit->Customize (F3). On the Right side, select Menus. In the Item list, open the drop down for Main Menu then &Edit. On the left side, open the Edit drop down. Find the Garibaldi entry and drag it to the point on the right side where you want it to appear. Click Accept.
You should now have the enrty back in the Edit menu.
Thank you so much!! This is what I needed!!!
