Eyes popping out (Morph Loader Pro) (Solved)
erkanyavuz1997erkanyavuz1997 Posts: 5
edited March 2024 in New Users
I created a G8F character by using Morph Loader Pro which i created it in blender. When I try to get her to look away the eyes popping out. I added a picture below showing the problem. How can i solve the problem any idea?
616 x 650 - 155K
Post edited by erkanyavuz1997 on
  • crosswindcrosswind Posts: 10,344
    After importing the morph with MLP, make sure you firstly do Adjust Rigging to Shape and ERC Freeze on the morph property before giving any expression to the figure.
  • Richard HaseltineRichard Haseltine Posts: 111,854
    Edit>Figure>Rigging>Adjust rigging to Shape. You can then test it, assuming ti works you then use ERC Freeze to link the adjustments to the morph - right-click in the Parameters pane and check Edit Mode (if it isn't already), reset the pose, right-click on the slider for your morph and select ERC Freeze - look through the list of sub-components to make sure there are no interlopers, uncheck them if there are (you mainly should see joint centre adjustments), click Accept and test again to make sure everything worked, and that the figure goes back to normal when you zero your morph.
  • Thank you very much I didn't know it was actually this easy, It works fine.
