Body morph looks great but messes up the breast
josiahmora20josiahmora20 Posts: 83
edited March 2024 in The Commons
I have a G9F character nearly done but one problem remains that I can't seem to fix with any morph pack I throw at it. I blended multiple bodies together to get a base shape that I liked, but it did something weird to the breasts where they are now a weird shape. The breast itself is warped a little which i CAN fix with the morphs, but the nipples aren't circular anymore and when i try to extend the nipples with any morph they get sharp. I found Shape Splitter on Daz store but it doesnt look like it supports gen9. Is there any other way I omit the breasts from the body morph that's messing it up?
Post edited by josiahmora20 on
  • Richard HaseltineRichard Haseltine Posts: 111,371
    What do you mean by blended? If you exported them as OBJ and then loaded that as a single new morph then you will have broken the links to any joint adjustments or corrective morphs that were making the morphs used play nicely with posing and other (suported) shapes, which may well be some or all of the problem you are seeing.
  • What do you mean by blended? If you exported them as OBJ and then loaded that as a single new morph then you will have broken the links to any joint adjustments or corrective morphs that were making the morphs used play nicely with posing and other (suported) shapes, which may well be some or all of the problem you are seeing.
    No I'm sorry, I'm new to Daz so I may not understand all the terminology- I bought some characters and they each have a slider called "body," which chnages their entire body (excluding the head), I took two bodies and morphed them together to get proportions I liked but combining them messed up the breasts.
    So the two body morphs are still set separately? What values have you given them - often going over 100% in total on body morphs will risk breaking things (that isn't an absolute rule, just a rough rule of thumb).
  • So the two body morphs are still set separately? What values have you given them - often going over 100% in total on body morphs will risk breaking things (that isn't an absolute rule, just a rough rule of thumb).
    Yeah one body is at 100% and the other at 30-ish%. It's the 100% one that's messing up the breasts but I really love the proportions it adds otherwise.
