IRAY rend error: CUDA device ... Kernel [21] (RoundedCorners ) failed after 0.002s
- Current Daz Client
- Current Nvidia Studio Drivers
- No problems rendering in general
- Checked for Transmitted color map issue
- Remove and reinstalled vendor asset using DIM
- No other Content Directories with vendor asset
Using Elegant Hair for Genesis 8 and 8.1 Females , causes an access violation in the Iray engine. I've narrowed it down to this product and confirmed if I hide the asset, Iray renders fine;
With product hidden
2024-03-09 10:40:44.833 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...<br />
2024-03-09 10:40:44.833 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): Processing scene...<br />
2024-03-09 10:40:45.948 Iray [INFO] - IRAY:RENDER :: 1.4 IRAY rend info : Importing lights for motion time 0<br />
2024-03-09 10:40:45.948 Iray [INFO] - IRAY:RENDER :: 1.4 IRAY rend info : Initializing light hierarchy.<br />
2024-03-09 10:40:45.948 Iray [INFO] - IRAY:RENDER :: 1.4 IRAY rend info : Light hierarchy initialization took 0.000 s<br />
2024-03-09 10:40:45.966 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Scene processed in 1.134s<br />
2024-03-09 10:40:45.968 Iray [INFO] - IRAY:RENDER :: 1.4 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Allocated 26.761 MiB for frame buffer<br />
2024-03-09 10:40:45.973 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Allocated 1.969 GiB of work space (2048k active samples in 0.005s)<br />
2024-03-09 10:40:45.973 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Optimizing for cooperative usage (performance could be sacrificed)<br />
2024-03-09 10:40:46.111 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00001 iteration after 1.269 s.<br />
2024-03-09 10:40:46.115 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...<br />
2024-03-09 10:40:46.168 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00003 iterations after 1.321 s.<br />
2024-03-09 10:40:46.252 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00007 iterations after 1.406 s.<br />
2024-03-09 10:40:46.388 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00015 iterations after 1.542 s.<br />
2024-03-09 10:40:46.586 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00027 iterations after 1.739 s.<br />
2024-03-09 10:40:46.789 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00039 iterations after 1.943 s.<br />
2024-03-09 10:40:46.992 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00051 iterations after 2.146 s.<br />
2024-03-09 10:40:47.172 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00062 iterations after 2.326 s.<br />
2024-03-09 10:40:47.378 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00074 iterations after 2.532 s.
With Product visibile
2024-03-09 10:26:39.238 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...<br />
2024-03-09 10:26:39.238 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend progr: CUDA device 0 (NVIDIA GeForce RTX 3090): Processing scene...<br />
2024-03-09 10:26:40.538 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : Importing lights for motion time 0<br />
2024-03-09 10:26:40.538 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : Initializing light hierarchy.<br />
2024-03-09 10:26:40.538 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : Light hierarchy initialization took 0.000 s<br />
2024-03-09 10:26:40.638 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : JIT-linking wavefront kernel in 0.058 s<br />
2024-03-09 10:26:40.644 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Scene processed in 1.406s<br />
2024-03-09 10:26:40.645 Iray [INFO] - IRAY:RENDER :: 1.2 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Allocated 26.761 MiB for frame buffer<br />
2024-03-09 10:26:40.650 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Allocated 1.969 GiB of work space (2048k active samples in 0.005s)<br />
2024-03-09 10:26:40.650 Iray [INFO] - IRAY:RENDER :: 1.3 IRAY rend info : CUDA device 0 (NVIDIA GeForce RTX 3090): Optimizing for cooperative usage (performance could be sacrificed)<br />
2024-03-09 10:26:40.821 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00001 iteration after 1.575 s.<br />
2024-03-09 10:26:40.826 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Rendering...<br />
2024-03-09 10:26:40.897 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Received update to 00002 iterations after 1.646 s.<br />
<span class="marker">2024-03-09 10:26:40.975 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.34 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): Kernel [21] (RoundedCorners ) failed after 0.002s</span><br />
2024-03-09 10:26:40.975 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.34 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): an illegal memory access was encountered (while launching CUDA renderer in <internal>:908)<br />
2024-03-09 10:26:40.975 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.34 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): Failed to launch renderer<br />
2024-03-09 10:26:40.976 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.3 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): Device failed while rendering<br />
2024-03-09 10:26:40.976 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - IRAY:RENDER :: 1.3 IRAY rend warn : CUDA device 0 (NVIDIA GeForce RTX 3090) is no longer available for rendering.<br />
2024-03-09 10:26:40.976 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - IRAY:RENDER :: 1.3 IRAY rend warn : All available GPUs failed.<br />
2024-03-09 10:26:40.976 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.3 IRAY rend error: Fallback to CPU not allowed.<br />
2024-03-09 10:26:40.976 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [WARNING] - IRAY:RENDER :: 1.3 IRAY rend warn : Re-rendering iteration because of device failure<br />
2024-03-09 10:26:40.977 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.3 IRAY rend error: All workers failed: aborting render<br />
2024-03-09 10:26:40.977 [WARNING] :: \src\pluginsource\DzIrayRender\dzneuraymgr.cpp(376): Iray [ERROR] - IRAY:RENDER :: 1.3 IRAY rend error: CUDA device 0 (NVIDIA GeForce RTX 3090): an illegal memory access was encountered (while de-allocating memory)<br />
Once the iray engine AV's, I need to restart Daz (expected).
Has anyone else seem something similar, or if someone has this asset can they try to reproduce?
