V4 LOD
Hello,
I don't understand how can I use lower defination versions of V4... can someone expliain?
Under level of resolution I see only "Base"...
Hello,
You need to load the new LoD meshes - Edit>Figure>Geometry>Add level of Detail. The OBJ files are in \Runtime\Libraries\DAZPeople\bl_MilWom_v4b_LOD, pick one, in the OBJ import options select the Poser preset, and give your LoD a name in the last dialogue. Repeat to add other levels as desired.
I don't seem to have those file in my folder...
reinstalled the base content via DAZ3DIM and now they are there... thank you!
