Open old "My Daz 3D library" in new DS 4.8
I just lost my drive with DS 4.8 and "My DAZ 3D library" but am able to copy the "My DAZ 3D library to another disc. How do I hook it into a newly installed version of DS on the same disc?
Install daz3d open and go to right side "Content Library"
1: this way
- On default DAZ STUDIO FORMAT, right click mouse and on the menu select ADD A BASE DIRECTORY
Navigate where your personal library located
2: other way
once is highlighted check the menu CONTENT DIRECTORY MANAGER
select your HD PATH where your library is copy or just replace the default install library with your path
Once you do that,
It needs to scan your libraries for metadata.
To clear smart content and reload all
Use the menu CONTENT DB MAINTENANCE
Use RESET DATABASE,
Once all is clean, use again the menu and select RE-IMPORT METADATA
Normal all donne
