Using an old video card in DAZ
I suspect the solution to this is "get a new card" but I can't afford to at the moment so maybe there is a work around.
A day or so ago my 2080 RTX Ti card took a big dirt nap so I was forced to go back to using my old GTX Titan card. Unfortunately the titan's drivers top out at version 470 something but in order to use the GPU when rendering DAZ wants driver version 522 or better.
Is there someway to get more recent drivers for the titan? The geforce experience program says that it has the most recent version at 47x. Or is there a way to get DAZ to use the GPUs anyway?
  • Richard HaseltineRichard Haseltine Posts: 112,066
    You don't have a non-nVidia GPU you could use? I assume, though can't verify, that if there is no nVidia card and so no driver at all Iray just works on the CPU (otherwise AMD users wouldn't be able to render at all). Of coruse you would then run into the issue with AMD OpenCL suport blocing dForce, unless you could use the Intel CPU OpenCL driver.
