No Iray on 4.21/4.22 (updated A6000 drivers)
Hello!
I have Studio 4.20 and 4.22 installed. 4.20 works as intended, 4.22 has no Iray options (neither as render engine in render settings, nor in the viewport). I had the same issue with 4.21, so I figured I'd wait for the newer version, but it's still very much a problem. Just to clarify: it's not that Iray doesn't work, but Iray not being an option in the entire program. It's not there.
Normally this suggests driver issues (in my experience at least), but I just installed the latest drivers again (today). I have an NVIDIA RTX A6000 48gb, which should be supported? Can't really find the documentation, but I read people use it for Daz. It works like a charm for all my other 3d work/applications, anyway.
Any idea what else I can do? Thanks in advance!
  • Richard HaseltineRichard Haseltine Posts: 111,363
    What is your driver version?
  • crosswindcrosswind Posts: 10,249
    No issue on my side with driver ver. 551.61, in both 4.22.0.16 General Release and 4.22.1.88 Public Build.  Have you check the NVIDIA Iray Renderer plugin via Help - About Installed Plugins...? Is it activated ?
    1381 x 1393 - 214K
    1916 x 1395 - 225K
