C4D Bridge to DAZ 3D Studio Install
Hallo,
I have had a problem for a very long time. The Bridge c4d to DAZ 3D is not installed, it just doesn't work. I've tried it many times, but it doesn't make any sense. The tutorials didn't help either. Can someone please help me? I work with Mac (see pictures).
anks alot
Reza from Germany
1200 x 998 - 155K
590 x 357 - 76K
  • GordigGordig Posts: 10,810
    I don't know if it's a translation error or a misunderstanding, but the bridge is FROM Daz Studio TO C4D, not the other way around. R26 should be supported, so the first step is to "buy" the bridge from the store, if you haven't already, then install the bridge to DS, if you haven't already. Within DS, the bridge is located in the File menu under Send To, and from there you get the option to install the other side of the bridge to C4D by pointing it to your plugins folder.
  • BigMacBigMac Posts: 97
    Hi,
    thank you very much for your help. You're right, I made mistakes. “DAZ to Cinema4D” is correct. As you said, I bought the Bridge and tried to install it in DAZ Centralle but that doesn't work. DAZ Centrall crashes after 10 seconds or the wheel spins forever and doesn't happen. There is nothing in the file either (picture). Maybe it's because I work with Apple and it's not compatible with DAZ Studio...??
    I apologize for my bad English, Google helps me
    Reza
    1876 x 1352 - 859K
    1435 x 1401 - 1M
    1696 x 1077 - 437K
    I think Daz Central has trouble with plugins, and is also deprecated, so it's not the recommended way to install. Give DIM (Daz Install Manager) a try and see if that successfully installs the plugin.
    Thank you very much and I will try that.
    All the best
    Reza
