DIM Issue or something else?
Installing clean content to new win 10 laptop.
I've moved my content to a partition and mapped with Studio 4.8 64 bit
when I navigate the the Daz Studio/Figures/Daz People folder I see all the figures I've downloaded from the DIM this morning, but I don't see V4
If I browse to the folder I see all those figures have a CR2, a DSB and a PNG associated with them except for V4, that only has the DSB file.
I've uninstalled and reinstalled the base figure from the DIM and there is no change.
Also when I attempt to DL V4 ethnic faces I get an error "Download Failed!", apparently I need to go to the order from the webpage and download manually. The Install Manager Ready links do nothing when I select them.
Is this correct behavior?
Install Manager 1.1.0.41
  • Are you looking under Poser Formats or DAZ Studio Formats? Which files ddi you install?
  • StratDragonStratDragon Posts: 3,290
    what was in my ready to download list
    victoria 4.2 base
    victoria 4.2 base power loader
    victoria 4.2 Base studioCF
    these all appear in my "installed" list.
  • Then the figure should be in Poser Formats>My DAZ 3D Library>Figures>DAZ People. Check the Installed Files list (from the little triangle button on the right of the DIM entry) for the Victoria 4.2 Base.
    that where I looked, only the DSB file is present for V4. All other figures are there represented with 3 files, the PNG, the CR2 and DSB
    the Win10 computer is not in front of me now,  but I can scour the drive later to see if those other files were left elsewhere. I should have the actual installer and I can see if it's possible to run without DIM. On my Mac right now so I can't test.
  • RuphussRuphuss Posts: 2,631
    did you checked install to selected path in DIM ?
    i had exactly the same issue
    i hope that was causing it
    going to check tonight when time allows. I think the path is set but it's defiantly not the default path. my content is on a 2nd partition.
