Manual Download and Install
Hallo
Can anyone please tell me where the downloaded zip files should go? I have installed DS4.8 Pro from scratch because was not sure about the directories paths. Now I want to know where the other files like Genesis and Genesis male/Female Essentials should go. I already unzipped the files and most of it contains a content folder and manifest file. How do you install these and to which directory? Thanks everyone. Forgot to add that Im running Windows 7 64bit
Post edited by fdc on
The files and folders in the Content folder go in My Daz £D Library in the Public Documents folder or in \DAZ 3D|Studio\My Library in your own documents folder, if you use the default paths in DS. The Content folder itself and the Manifest file are not needed. If you are uncertain it's best to use the default locations and isntall with the Install Manager initially.
The contents of the Content folder from the extracted zip go into your My Library folder (if you left it at its default name).
Thank you very much for the info. I will give it a try
Actually they can go pretty much anywhere you want as long as you tell Studio where they are. And if you are going to install manually you might as well just exact the entire "Content" folder and point Studio to it as your library folder.
