Is there an auto center feature?
SchaakaSchaaka Posts: 165
Is there an auto center feature? As you can see in the pic the joints are off to the side, is there a button that will automatically center it back to the main geometry?
I know I can adjust the joints manually or I can create a new group and it will have the same effect but just wondering if such a thing exists?
996 x 868 - 71K
  • Richard HaseltineRichard Haseltine Posts: 111,992
    If this is a figure you have moved it using the root bone (the equivalent of the hip) so it is now displaced from the figure node - it is best to move things around using the figure node, and keep the root bone for adjustments for the pose (to keep the item in contact with the ground, or to place it relative to another figure).
