Does Heat Animation Plugin work with Genesis 2?
So, just want to confirm or deny, can Heat Animation Plugin work with Genesis 2 male or female? Genesis 3? Or is it strictly only 8 and 9?
Either way, glad to see all this new emphasis on animation!
HEAT animations are only for Genesis 8 and 9 according to the plugin doc:
https://docs.heat.tech/daz-3d-plugin/daz3d-with-heat-bridge
there are ways to convert animations between generations
Well I suppose you could try using the plugin on G8F to create an animation, save a G8F animated pose from your scene, then use a converter to transfer that animated pose to G2F.
But the plugin won't work directly with G2F.
Seems only G8-9
How do I do that?
https://www.daz3d.com/forums/discussion/605941/genesis-1-2-3-8-9-to-genesis-3-8-9-pose-converter-updated-2023-04-28#latest
https://www.daz3d.com/catalogsearch/result?q=minion
There is no mention of minimum DS version for the plugin...
Several options for you!
Generation-Animation-Conversion
