Recovery software
PerttiAPerttiA Posts: 10,024
Ok, the day did come... One of my external drives stopped working and doesn't show up in Windows Exprorer.
In Computer Management, I can find it, but it's showing "Not Iniatilized"
Removed the drive from it's enclosure and used a docking station, no success
Haven't tried connecting it to internal SATA yet and don't think it will change anything
It has been a quite a number of years since I had to use recovery software and can't remember which one(s) I used the last time
Which software has been successfully used in recovering files from such drive (no subscription licenses)
I'm looking one that's free or up to $100 for one that makes me coffee and my first born.
Post edited by PerttiA on
  • FishtalesFishtales Posts: 6,244
    Have you tried to Rebuild MBR? Open the Command Prompt and run as administrator, then run the command lines bootrec/fixmbr and bootrec/fixboot.
    Didn't try as I have bad experience with included tools to 'fix' anything, but will check.
    The drive was formated with NTFS and wasn't bootable. There were no symptoms before, so I don't think the problem is physical.
    I have used the EaseUS programmes and find them good and they do a Data Recovery programme.
    https://www.easeus.com/data-recovery-software/
    Thanks, downloaded the free trial executable, lifetime license doesn't mention anything about making coffee wink
    Thay are doing a nice priced bundle just now.
    https://www.easeus.com/datarecoverywizardpro/drw-pro-buy.html?linkid=e_drw_win_family
    I have Backup Home and it runs in the background.
  • MattymanxMattymanx Posts: 7,002
    It may be a good idea to check the manufacture of the hard drive and see if their website has any software that can help, including software to do a SMART test.
    You may consider downloading the bootable Gparted image and seeing if it can access the drive at all - https://gparted.org/livecd.php - boots from USB as well.
  • stem_athomestem_athome Posts: 526
    Hi,
    I use Lazesoft Recovery Suite (free for home use):-  https://lazesoft.com/
    edited March 2024
    Thanks, checking it out.
    Scanning the 4TB drive goes very slow and I may have to wait for the next weekend to finish.
    Edit; So far the only program that is able to see the drive
  • 31415926543141592654 Posts: 975
    Probably not the cheapest ... probably not the best ... but when I had a drive fail I tried Recoverit ... cost was about $75 and was good for a year. It did salvage most of my files - though the folder structures were laregly gone. But it was slow - it was a 4 or 5 TB drive - it scanned the drive for almost 24 hours and took another 12 to copy them to a new drive ... and I dared not stop the thing once it started because I think it would start over.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,829
    edited March 2024
    since this thread is fresh
     I just accidently permenantly deleted a folder in Win10
    Winfr C: J: /regular /n \Users\Public\Documents\Reallusion\Custom\iClone 6 Custom\
    gives me
    There was an error parsing your command. Please check /? for more information and try again.
    in Windows File Recovery tool, I have no idea what I have wrong in the syntax reading the instructions
    it was a huge folder too with heaps of user data mostly DAZ imports to iClone, just about everything I ever imported basically and all my scenes
    gives me
    When reading the Microsoft guide, they give conflicting advice (surprice) about the syntax.
    In one place they say the syntax is "Winfr C: E: /regular /n \Users\<username>\Documents\"
    In another place they say it's "/n /users/<username>/Documents/"
    The bad thing is that the files are on C-drive, where Windows is constantly writing over those files, so installing new programs is a bad idea.
    Removing the drive and connecting it to another (Windows) computer may not work either because it is the OS drive with MS specified standard folders - One may not even see the folders on that drive, but the ones on the OS drive of that other computer.
    edited March 2024
    I eventually did get it to work skipping the subfolder paths
    ie Winfr C: J: /regular /n \Users\Public\Documents\Reallusion\, but it did not recover all of it and not in a folder hierarchy either
    so yeah SSD too and overwritten
    but got all my iMotions back by looks which is a huge help as I can export those to DAZ now for Genesis 9 with bone minion and M4
    as I was slowly doing
    I was also rendering this in DAZ when I did it cheeky
    (accidently deleted folder)
    a 4K video!!! but I was rendering to an external drive
    probably didn't help though
