simple 5 pointed star obj?
IkyotoIkyoto Posts: 1,159
edited December 2015 in The Commons
I could use one if anyone has a lead.
Post edited by Ikyoto on
  • Flat, or do you need it to have some dimensionality, such as beveled edges?
  • Richard HaseltineRichard Haseltine Posts: 111,674
    For a very basic star you can do it in DS:
    Create a cylinder, I've set the axis to Z but that isn't vital - what is important is giving the cylinder ten sides (five points, five indents) and one segment (so you don't have too much fiddling to do, though you could add more if you wanted a degree of rounding).
    Create cylinder
    Create a DForm and move the field right out of the way.
    Remove field
    Set the DForm itself to scale down the cylinder's width - in my case that's x-scale and y-scale.
    Set scaling
    Swiitch to the Node Weight Map Brush tool and open Tool Settings, with one of the DForm parts selected
    In Tool Settings click Add Map nextt o Influence Weights.
    Apply weight map
    Now in the viewport paint on every other set of side vertices, front and back - it's easiest to do this in wire shaded view. Make sure you hit only the indent vetices, not the points - it doesn't matter if you hit the mid point as it won't move whatever the weight is since it's in the centre of the scale effect. Keep painting until the points stop moving - that's 100% effect, if you try stopping part way it will be impossible to keep everything even.
    Paint weights
    When done you can use the slider under the map to adjust the depth of the indents.
    Adjust
    270 x 344 - 23K
    1281 x 856 - 89K
    1093 x 693 - 78K
    1390 x 585 - 78K
    683 x 688 - 48K
    1490 x 610 - 88K
  • Charlie JudgeCharlie Judge Posts: 13,639
    Free beveled includes obj: http://www.turbosquid.com/3d-models/star-3ds/378264
    Free beveled includes obj: http://www.turbosquid.com/3d-models/20-face-star-3ds-free/535674
    Free flat includes obj: http://www.turbosquid.com/3d-models/free-3ds-mode-star/664920
    Free flat but 3DS only: http://www.turbosquid.com/3d-models/free-star-3d-model/533342
    And more available at Turbo -- Search for ' star ' and sort by price low to high
    Post edited by Charlie Judge on
  • RGcincyRGcincy Posts: 2,864
    I have several .obj in this free Christmas kit. Works in Bryce, Daz Stiudio 4.8, and other 3D programs. Textures not included.
    Post edited by RGcincy on
  • FistyFisty Posts: 3,416
    Perfect jewlery boxes has a star box, the lid works well for some things.  It was a weekly freebie, you likely have it in your account.
    http://www.daz3d.com/perfect-jewelry-boxes
    Richard, your method works very well...with a few minor modifications in Blender laugh
    Cranked this out in about 10 mins, including UV mapping it.
    1000 x 800 - 642K
    Post edited by mjc1016 on
    mjc1016:  It looks very nice. Have you considered uploading it to your sharecg gallery?
    Thanks,
         Charlie
    Well, after I get some textures for the bell, too...not going to do balls or fancy ones, I'll throw them on there...
  • IkyotoIkyoto Posts: 1,159
    Could this threa be any more fun? You folk made my season
