Viewing Figures as Neutral Gray Sculptures
I've been playing with DS for a couple of months now, and whilr the full colour figures are great, what I'm really looking for is simple grayscale figures to use as illustration reference. Is there a way to view my poses in preview as gray "sculptures" or is it something that can only be done as renders? And if only as renders, how?
    You could make a very basic grey shader and apply that.
    In D/S Create a sphere. It is grey ... actually could make it any colour you want to. When it is as desired, then File > Save as > Shader preset ... can save that into any folder in "My Library" but not the runtime. So for example you could save it to the People > Genesis [or whichever] folder so it's right there for use. To apply a shader, both the figure and the surfaces must be selected. On the surface tab if you select the main figure they will "all" be selected.
  • 3WC3WC Posts: 1,170
    edited December 2015
    Or just change your view mode to "Smooth shaded".
    869 x 458 - 88K
    Post edited by 3WC on
  • fastbike1fastbike1 Posts: 4,084
    I have had good luck with the G2F/G2M and G3F Grey mats from Spyrorue at Sharecg. Spryorue also has a G3F reset pose set.
  • Thanks for all the suggetions, appreciate it.
