Celebrity Red Carpet not working
3DScreencraft
in The Commons
Hi all, I installed the Celebrity Red Carpet as usual, through the DIM, but when I open the product in DS the thumbs come up as then exclamation/triangle. When I try to install it says the files aren't installed. I uninstalled (via DIM), then downloaded and installed again. Same result. Is the package missing some files, maybe?
Thanks!
I don't have that product but it sounds like perhaps there is a mismatch between what DIM thinks is the correct path and what is actually there. Sometimes files are moved during the packaging stage and so the install does not complete correctly.
If you right click on it in DIM and select "Show installed files" - you want all files to show up as links there. On OSX the links are blue and "missing" files are grey. The wiki says that the path for the user-facing files are stored under "Environments/Architecture/Silent Winter/Celebrity Red Carpet/" - can you see if that is where they actually are?
I've had this happen with a few products. I ultimately had to manually install them.
Firstly: Thanks for your purchase :)
Secondly: I've not heard about files being moved. It's possibly a DIM/download/install issue - so check the path as mentioned by SofaCitizen above.
I've just downloaded the manual-install zip file and there are no apparent issues there. All the files are in the right place and the png thumbnails show up as expected.
If there's no solution there - you'd need to file a ticket with Daz Customer Support as I'm unable do anything about DIM or the way the files are packed up on the Daz side.
Let me know if this gets resolved or not as I may also need to send a ticket to Daz if it's a packaging issue.
Works great for me in Daz Studio Beta 4.22.1.74.
I have installed it via DIM, as usual. Very nice package, by the way.
Just checked, how it looks like with Genesis 9, for example https://www.daz3d.com/tao-hd-for-genesis-9-feminine
Thanks Artini :)
Cool render
Thank you, Silent Winter, I really enjoy exploring Celebrity Red Carpet places and make renders with it.
Thanks for your input, everyone - will try again. :)
