How to turn off highlighting bits when you wave your mouse across the scene
There's a menu setting for this, but for the life of me, I can't remember where it is. When you move the mouse, Daz highlights everything you touch in yellow. Very distracting. How do you disable this "feature", other than clicking the checkmark in the scene tab next to each node and turning the checkmark into an X.
    You need to go to Window > Panes (Tabs) > Draw Settings, and change the Draw Style to 'Bounding Box Only'    It used to be in Tool Settings I believe.
  • Perfect! Thank you so much!!
  • dracorndracorn Posts: 2,379
    ???  I decided to give that a try.  My figure turned into a bounding box instead, whether I changed Draw Style in Editor or Advanced.
    What did I miss?
  • SzarkSzark Posts: 10,634
    Editor Tab > General > Manipulation look at Manipulation Draw Style and see if it is set to Use Current (Off)
  • RLSprouseRLSprouse Posts: 288
    edited December 2015
    Window > Panes (Tabs) > Draw Settings > Editor tab > General > Node Highlighting - set the Active Opacity to zero (or your preferred value, default is 30%).
    Post edited by RLSprouse on
