Cannot export nodes without base figure (clothes, for example)
In older Versions of this plugins, only selcted nodes (clothes for example) have been exported (with the base skeleton). With the newer version, if I select only the clothes, the main character mesh automatically gets selected and is exported too.
How can I export only selected nodes without the character mesh?
To export the parts you want you need to of course need to select the main character form, assuming Genesis, you would take the parts you don't want to export and make them invisible. With the main figure, Genesis, selected you would then check "excluded invisible" and included clothing clothing as part of the Genesis structure. Now when you export the parts you don't want are excluded and the parts you want are exported using the Genesis skeletal rig.
Thank you very much, that did the trick *cheers*. I selected ONLY the main figurine and not the parts, I wanted to export, and it worked!
