Smoothing modifier not applied during image series render
Dolce SaitoDolce Saito Posts: 197
edited February 2024 in Daz Studio Discussion
When I render image series, smoothing modifier is lost after first frame. The behavior is unstable.
Sometimes it is applied one frame and not the other, but mostly, it simply switches itself "off" behind the scenes. Please note that the viewport and render subD's are kept equal for all rendered objects.
If I preview iray on viewport, the smoothing is applied properly. If I render image series, then the smoothing modifier switches itself off for everything in the scene, mostly after first rendered image in the sequence.
Is this known? Anyone else having this issue? What might be wrong?
Post edited by Dolce Saito on
  • What is advancing the Timeline? Keys set manually on the Timeline, keys created by a script or plug-in, AniMate playing an AniBlock?
  • Dolce SaitoDolce Saito Posts: 197
     Hi Richard. Neither scripts-plugins, nor animate (In fact, animate plugin is completely disabled). Just manual keys. As raw as possible.
    Also, I always delete "Actor" keyframes under "properties" from the timeline except the frame 0. I do this for all characters to make sure that characters never "shapeshift" on the fly either intentionally or mistakenly. A personal habit.
  • So everything is baked to the bone rotations. Any use of IK targets (as opposed to using it in posing, but leaving the result as transforms)?
     No IK targets I guess. I developed a double keyframing technique to overcome tcb value skewing. So, they are also raw.
    Pose on the viewport, double keyframe, pose again, double keyframe, and so on.
  • do you have the geometry editor selected?
  • No, I always keep it at selection tool to avoid mistakenly moving something on the viewport.
    Just to clear any misunderstanding: When I said "smoothing modifier switches itself off". I did not mean literally. It is on, but it just doesn't get applied after the first image being rendered during image series. The first image is always ok and correct.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,492
    increase the lock distance maybe
    is it dforced?
    if it is don't have the smoothing modifier on when you simulate it
    is it dforced?
    No, there is no dforce neither. This subject is solely under image series rendering and smoothing modifier. As I wrote in the main message, the viewport is ok. During the image series render, after the first image being rendered, the second and the rest has no smoothing modifier applied to the clothes in the scene. Smoothing modifier simply stops applying. Nothing to do with its parameters.
  • felisfelis Posts: 6,501
    What happens if you set Interactive Update to On for the smoothing mofifier?
  • Dolce Saito said:
    is it dforced?
    I cannot help you then, I do lots of animations and can only suggest things that cause me issues crying
     I'll give this a try.
    Edit: Unfortunately, interactive update didn't work neither. Problem persists. I'm looking for any case Richard mentioned, but I might have missed. Somehow, it made me question why smoothing modifier simply stops functioning after the first frame in the image series.
  • Hi, did you found solution? I am experiencing same problem :(
  • I encountered this issue three years ago. The problem is that iRay doesn't render while waiting for the smoothing modifier to finish calculating, whereas the Octane renderer doesn't have this issue.
  • maciejkrutul90说:
    你好,你找到解决方法了吗?我也遇到了同样的问题 :(
    var renderMgr = App.getRenderMgr();var scene = Scene;var renderOptions = renderMgr.getRenderOptions();var startFrame = 0;var endFrame = 2;var currentFrame = startFrame;var outputDir = "C:/Users/BinSh/Pictures/vr"; // Custom output directoryvar filePrefix = "frame_";// --- Render the next frame ---function renderNextFrame(){    // Set the filename before rendering    var frameStr = ("0000" + currentFrame).slice(-4);    renderOptions.renderImgFilename = outputDir + "/" + filePrefix + frameStr + ".png";    print("Rendering frame " + currentFrame + " -> " + renderOptions.renderImgFilename);    // Move to the current frame    scene.setFrame(currentFrame);    scene.update();    renderMgr.doRender();}// --- Callback after a render finishes ---function onRenderFinished(succeeded){    if(!succeeded){        print("Frame " + currentFrame + " failed.");    } else {        print("Frame " + currentFrame + " saved: " + renderOptions.renderImgFilename);    }    currentFrame++;    if(currentFrame > endFrame){        renderMgr.renderFinished.disconnect(onRenderFinished);        print("=== All frames rendered and saved ===");        return;    }    renderNextFrame();}// --- Connect the render finished signal and start the first frame ---renderMgr.renderFinished.connect(onRenderFinished);renderNextFrame();
    This is an automated rendering script. The image series has bugs; please set the render type to still image and the render target to direct to file. Open the script IDE window, copy the script, modify the outputDir, then click the execute button. If any error occurs during execution, ask ChatGPT.
