Help Genesis 8 Male
Hello friends.
I have this small problem with Genesis 8 Male, when I do a pose his left shoulder is a little strange, apparently the bones look good, I already tried to adjust the rig from Edit+Figure+Rigging+Adjust Rigging to Shape...but the problem persists.
I tried to uninstall the figure and the program but everything remains the same.
Does anyone know how to fix this?
Thanks for the prompt response. cheeky
805 x 682 - 411K
1060 x 799 - 440K
  • crosswindcrosswind Posts: 10,344
    edited January 2024
    The issue probably comes from other wrongly-defined body morph(s) or corrective morph(s). Go to Parameters pane, Show Hidden Properties from the hambergur menu, select Currently Used. Then check if there's any property unexpectedly dialed.
    Then identify the related product(s), uninstall them and send a ticket to Daz asking for a fix. If you wanna fix them yourself at the same time, post a screenshot of what you found...
    1977 x 1399 - 474K
    Post edited by crosswind on
  • PatrickPatrick Posts: 18
    Thank you
