Solved - Still Confused about my Viewport
JasmineSkunkJasmineSkunk Posts: 1,906
edited January 2024 in The Commons
SO I still feel like I don't understand my camera/settings/viewport/render.... yadayadayada.
For example, I have a primitive I am trying to test shaders on and when I have it facing directly at me facing front, I can see it in the viewport just fine, but if I rotate the camera at all, it goes completely black. I have toggled "preview lights" switch in the Windows tab, tried all the dome and scene, dome only, sky only, blah blah blah -in the environment tab and toggled the headlamp settings in both the render tab and the camera tab...and nothing changes it. Is there a way to see this at any angle in the viewport?
1920 x 1080 - 351K
1920 x 1080 - 316K
Post edited by JasmineSkunk on
  • crosswindcrosswind Posts: 10,344
    edited January 2024
    Usually, if there's a texture map in Base Color slot, but the color is set to black or sth. like dark grey, you'll have such an "issue". Pls check if that's the case...
    2560 x 1400 - 723K
    Post edited by crosswind on
  • JasmineSkunkJasmineSkunk Posts: 1,906
    No, the base color is white. See below
    1920 x 1080 - 364K
  • felisfelis Posts: 6,597
    I think it is because your Diffuse Weight is 0.
    edited January 2024
    Oh, that's it ~ or you better change Base Mixing to PBR Metallicity ~~ which is better than Weighted. PBR Weighted is calculated based on Diffuse Weight and Glossy Weight, may be better for some fabric like velvet. But for a cotton fabric which has very less glossiness, it's not a good setting...
    Or setting Diffuse Weight to 1.0, Glossy Weight to <0.5, may be a good combo.
    1920 x 1087 - 1022K
    Thanks guys! Yeah... I guess that's how these were set up.
    All the shaders load in as weighted and the weight is at zero. I wonder if there was a reason? LOL... Idk! but that helped! Thank you! smiley
