Please update Figure Measure Metrics for Genesis 9
EZ3DTVEZ3DTV Posts: 1,635
With the height differences between Genesis 9 and Genesis 8 figures it would be nice to have measure metrics updated so it works with Genesis 9 as well.
I have noticed a lot of updates for measure metrics in the install manager lately. I assumed they were to add functionality for Genesis 9 but I do not see that as being the case on further inspection.
Thanks
  • Richard HaseltineRichard Haseltine Posts: 111,374
    edited January 2024
    Moved to Technical help as it is not a Product Suggestion.
    Measure Metrics, like the other own-brand plug-ins, gets recompiled at each build - those are not, unless separately noted, updates in any meaningful sense. Also, Measure Metrics is an official daz product and so gets time allocated by management (or not, as the case may be) - Figure metrics is a PA prioduct and as such is limited by the time the PA is able to devote to it.
  • EZ3DTVEZ3DTV Posts: 1,635
    edited January 2024
    Considering the product does not have Genesis 9 functionality I assume this is indeed a "product suggestion".
    Unless you can solve the problem of it not working with Genesis 9?
    If you cannot solve this problem, please move this product suggestion back to the product suggestion forum so developers can consider this request.
    You can use Genesis 8 templates to add the metrics planes to the Genesis 9 figure but you cannot open the manger and edit the Genesis 9 figure's parameters.
    Post edited by EZ3DTV on
  • crosswindcrosswind Posts: 10,250
    Thanks
    Pls check the threads below in which I showed how to make MM work on G9... while waiting for official update...
    https://www.daz3d.com/forums/discussion/663636/measure-metrics-for-9
    https://www.daz3d.com/forums/discussion/667406/measurements-for-genesis-9
    Thanks for the help on this peeps, it is much appreciated. yes
  • I just bought it and it doesn't work. crying
    The plug-in or the script? Did you install both? DS 4 or DS 6? What happens when you try? If it's the script, Figure Metrics, are you using a supported figure and aplying the wearable for the actual measures?
  • Richard Haseltine said:
    V8 Infinite said:
    I just bought it and it doesn't work. pleurs
    The script itself doesn't do anything, I'm using DS 6, and it throws an error message.
    I tried it on Genesis 8 Female.
    1351 x 811 - 134K
  • Is Measure Metrics available in Window>Panes(Tabs)? Is it listed, with a green tick, in Help>About Installed Plug-ins?
    Yes, I have the panel in the interface (which I've pinned), and Measures Metrics is indeed checked in green under the installed plugins.
  • I am not sure what is going on, then.
