Create a new hierarchy category
I have created several custom morphs, and I know how to move them between existing categories under "Actor". What I would like to do is make a new category under "Actor" to place all my custom morphs in one spot. How do I make a new, empty category in the heirarchy?
Just type in manually in the Path field Actor/"your new menu name". DS will make the menu automatically. Than you need to resave the morphs.
Where is the path field to edit? That's what I cannot locate.
Click on the little gear icon on the morphs and select Parameter Settings.. This will open new window with "Path:" field.
I you wish to change path for more than 1 morph at once, click with right mouse button on the Parameters tab (on the letters Parameters) and from the menu activate Edit mode. Than press and hold Ctrl (Cmd for Mac) on the keyboard and click on the morphs to select them. When you are finished with selection, click with right mouse button on one of them to get a menu and from the menu select Set - Property Group.. and you will get Path field.
When you are done, right click on the parameters tab again to deactivate edit mode.
