3D Modeling - Do you add a little gap between a door and its frame?
JamesJames Posts: 1,190
I'm an amateur.
So I would like to know the practice.
When modeling interior, do you add a little gap between a door and it's frame?
Because when given a texture, without a gap they become like one solid object.
Post edited by James on
  • felisfelis Posts: 6,504
    I would leave a small space between the door and the frame.
    In real life, there need to be a gap, so you can open the door.
  • Yes, it bugs me when a (pivotting) door is tight to the fram since it then clips slightly when being opened.
  • RurisRuris Posts: 123
    James said:
    I'm an amateur.
    Definitely leave a gap, it will create a nice shadow when you test render it.
  • Model hinges for the door. That creates a space.
    I would recommend that you bevel the edges of the door and frame so they are not exactly 90 degree edges.  this will help add realizm to the model
  • When doing my little rigged door & wall model over at Rendo, I measured the door I was copying. Widthwise it was 3mm narrower than the frame and 6mm shorter, with a 2mm gap at the bottom and 4 at the top. The bevel that Mattymanx mentions was not something I did, instead I played with the Uber shader and set the 'Angle' at 90.1 degrees and the radius as 0.2cm, this leaves Iray to put in a 2mm fillet at all points where the surfaces came together. I set it NOT to blend across materials. When rigging it, the pivot was at the centre of the hinge model.
    Regards,
    Richard
