Problem with Transfer Utilty and V4
Hiello DAZ users,
I am trying to covert V4 morphs to G9 (for this I created V4 clone for G9).
I am loading V4 to scene and convert it to weight mapping, then importing the V4 clone to scene. After using the transfer utility they are both fitted in scene.
When I scale the V4 from parameters tab, they are both scaled. Bat when I inject morph on V4, the morph effects only V4 and not the clone.
Help appreciated.
  • Both fitted to what? Scaling would be inherited simply by being parented, regardless of being fitted.
  • G9 fitted to V4
  • V4 clone for G9 fitted to V4 (not parented).
  • If you open the Parameter Settings for the morph (from the gear icon on the slider) is Auto Follow enabled?
  • Changing "fit to mode" settings does not help.
  • I have problem only with V4. I tried this method with other generations of genesis (G1-G8) without any problems.
  • crosswindcrosswind Posts: 10,356
    edited January 2024
    The right way should be:
    - Inject Head and Body morphs on V4, export V4 to OBJ. Remove Head and Body morphs.
    - Convert V4 to TriAx or General Weight. Import OBJ to V4 as a Character Morph.
    - Import V4 Clone for G9 and rig it on V4 with Transfer Utility.
    - Dial Character Morph on V4, V4 Clone for G9 will follow.
    Then export V4 Clone to OBJ, import it to G9 with Morph Loader Pro + G9 HeadSplit dFormer...to create Head and Body morph separately.
    2032 x 1395 - 278K
    Post edited by crosswind on
