Clothes clone in reverse...
Hi all, I see that there are autofit clones for clothes going from V4 to the G2F model but are there clones that take G2F clothes and autofit them to V4?
Thanks!
  • LeanaLeana Posts: 13,686
    edited December 2015
    Autofit is for weightmapped figures, and V4 is not one. So no, there are no clones for V4.
    edit: if you want to convert G2F clothes to V4 your best bet is Evilinnocence's crossdresser program. It doesn't support G2F but it can convert Genesis 1 clothes to other figures, so if you have the G2F -> G1 clone you can autofit the G2F clothes to G1, save the converted clothes, and then use Crossdresser to convert those to V4.
    Post edited by Leana on
    Thanks for the advice :)
    Wow! Xdresser is the bomb!
    The next question is, how do you get the Genesis clothes that were made by the G2F-> G1 clone to pass into Xdresser? Do you save the clothes as a .cr2?
    Thank you!
    Thank you!
    From memory (I can't check from here) you need to export Genesis clothes as a cr2 in order to be able to convert them with Xdresser, so yes you would export the converted G2F clothes as cr2.
    Thanks again, I will give that a try!
