G8M base model loaded with wrong slides and features
dan_thomasdan_thomas Posts: 107
edited January 2024 in Daz Studio Discussion
I don't know when this started but if I load G8M base model, the model appeared with some cartoon slides set to 100%. I can easily reset those slides to zero. But I couldn't find any way to fix this problem in attached picture with any slides. Any hint or clue would be appreciated.
619 x 628 - 22K
Post edited by dan_thomas on
    The morph(s) providing those "horn sockets" have been saved with a non-zero initial value. To fix this:
    1. Load your G8M dev load figure
    2. Set all morphs to zero (you may have to show hidden ones)
    3. Memorise the Figure
    4. Save Modified Asset
    Thanks for your answer.
    My problem was that I got the picture even if I tried to set all morphs to zero. Then I realized that "Currently Used" list does not include any morphs with 100% default value. So I had to review hundreds morphs if not thousands. Anyway, I eventually found the offending morph but wondered if this is a good time to abandon this software for Blender.
