Texture not loading into "Diffuse Color"? Need help.
I'm getting a Daz symbol instead of the texture icon I loaded in the "Diffuse color" drop down of the surface editor. The material shows its checked marked on the drop down and it shows up on the model in the un-rendered scene. However, when i do render the scene, nothing is showing on the model but black. This happened after saving the scene and shutting down Daz and returning to it later. It was working and rendered properly before i saved and quit. The only thing I did since then is save the scene, quit daz, and i made a change to the texture in Gimp. Same file name and location. Anyone experience this and have a solution?
I had one do that to me the other day...ended up resaving it from GIMP to a new file name (added a 03 to the name) and loading that in Studio.
Well it resolved itself. I restarted daz and loaded the scene again and all is well......for now. :)
It's like the old version got 'stuck'...for me blowing out the temp folder and running the purge memory script didn't work...so instead restarting, I just renamed.
