Setting the view proportions?
Hi!
Embarrassing, but I havent found where to set the window proportions, for example 16:9 as seen in the video tutorials from Dreamlight, how is this done?
Kind Regards, Ingemar
  • barbultbarbult Posts: 27,471
    edited December 2015
    For Iray at least, it is in the Render Settings under the General Section..
    Post edited by barbult on
    Hi!
    As barbult  says, you set the proportions for your window in the render settings pane, but to see the frame in the Viewport, you have to turn on 'Show Aspect Frame' in the drop-down menu for the Viewport.
  • That simple! Thanks for your help.
