Genesis 8 basic figure loads with morphs applied
Hi guys first time posting here, i have had an amazing journey learning daz studio so far but today i stumbled on an issue where all my genesis 8 female figures ( even the basic figure) load with some morphs applied to them i tried zeroing the basic figure and saving but when i open daz again it still loads with those morphs i need your help please because it takes so much time to zero every figure i use
  • What characters for that figure have you isntalled recently? Have you tried creating your own morphs?
    This has unwanted side-effects with G9, but works for G8 and G8.1
    To fix any ill-behaving (non-zero default value) morphs, do as follows;
    1. Open DS and load "Genesis 8 Basic Female" (to an empty scene)
    2. Right Click at Parameters Tab->Preferences->Choose "Show Hidden Properties" (part 3 zeroes only 'visible' dials)
    3. Right Click at Parameters Tab->Zero->Zero Figure (Zeroes the value of all the 'visible' dials)
    4. Right Click at Parameters Tab->Memorize->Memorize Figure (Sets the current value of all the dials as their default value)
    5. Edit->Save As->Support Asset->Save Modified Assets (Writes the changed default value to the morph files that were changed)
    When saving "Modified Assets" DS shows a dialog and asks for confirmation;
    "The following file(s) will be permanently modified:" - "Accept/Cancel" - Choose "Accept"
    or make a note of what is affected and then Cancel - that should let you identify the problem and fix it directly
  • KenYanoKenYano Posts: 145
    Hey could someone help me with this? I have the same problem with a shap I saved as a suppport asset figure/prop and now my genesis 8 female loads with the face and body morphs. I followed the instructions but I haven't clicked accept. Do I click every option and sub option as shown my screenshot?
    701 x 714 - 77K
  • Richard HaseltineRichard Haseltine Posts: 111,958
    That is Save Modifier Asset, not Save Modified Assets (at the bottom of the list) - you could use that, unchecking all but your own, but using Save Modified should involve less unchecking (you stil want only your morphs that you are fixing, other things may need their non-zero values so leave them out unless you positively know they were wrong).
    I used Save Modified Assets and it worked. Thanks for the help!
  • nannerfkmnannerfkm Posts: 76
    Wow, glad I found this; it was driving me crazy. I mean I could zero the morphs out in shaping, but I had to do it everytime I loaded a new 8.1.
    Thanks!!!
  • This fixed it for me. Even for Genesis 9. Thanks
