Problem with Genesis 9 crotch
Hello. I know it can be a... peculiar and odd question, but I really need help with this.
When I modify Genesis 9 into a femenine form (it happens also with masculine form, but slightly less) and pose it, its... space between the legs appears all deformed and distorted as you can see in the pics.
from this...
...to this:
ok... it's not a HUGE issues when I use clothing (those too are pretty distorted, tho. I have to fix them with mesh grabber, often, if they are trousers or similars) but it is when I have to use a nude, as for greek statues or stuff.
What could it cause it? How can I fix it?
58K
90K
38K
  • ElorElor Posts: 4,264
    Hello,
    I had a similar problem a couple of months ago when a character I was not using had morphs loaded to other characters, so maybe it's the case too here.
    @lilweep's advice was as follow:
    Go to Parameters tab and make sure you have 'Preference>Show Hidden Properties' on.
    Look at 'Currently Used' parameters to see active morphs.
    Toggle them until you find faulty one(s).
  • Elor said:
    Hello,
    Thank you SO much. Really ^__^
    I fixed it wonderfully. THanks
