Genesis 3 figure morphing and Precise measurements
Is there a way to import measurements in cm so I can precisely moprh a model?
For example, I want the figures height to be 180cm, but in DAZ I can only slide a hieght slider up and down, which doesn't give me a value other than a percentage.
Thanks.
One way to do that is to create a primitive of the exact height you want (180cm) and then adjust the height to match.
I simply use two Null, to measure two point,,, eg head size or bust size, or bust size, or bust size, .. with authographic left, right, top view.
then circulate from two x, y, z.
So there's no way to input body measurements in cm
Are you serious? Surely there has to be a way.
http://www.daz3d.com/measure-metrics-for-daz-studio This should do it.
No joking Very Very serious
. what actually you hope? I feel, if you hope to see "cm" when you apply full character morphs ,
you can make it if you really need , by ERC and make new controller which auto change value with Each morphs, but first you need to check
between 100% to 0 %. eg FBMVictoria 6 100 % , x value. to zero shape x value.
basically DAZ unit is cm, in parameter tab, translation values. then if you use Null or obj to measure size, you can see it as cm.
then if you add rigidity follow node for target poligon , by geometery editor, the point auto follow mesh defomation.
then you can get current value of ridigity follow node as cm in parameter tab, but I prefere simply make null, then set positon, first,
and change morph value untill it fit to the null position. or you may buy measurement plug in,, though I do not think it fit your purpose,
to see current size as cm with changing morph value. it simply measure edge or vertex you selected I think.
Ah maybe the plug in fit your work . . (though I never think to buy plug in just for measurement purpose ^^;)
if 80% off,, I may thinking.
Besided the Height dial there are morph dials to adjust the length of the legs and torso, because of this there is no reliable way for the Height dial to use true physical measurements. You are going to have to learn be creative to get around these little quirks.
To be frankly said, the price of the plug in is too high for me when think what it can do, and the usage.
I have a measuring wall prop (don't remember where I got it) that I always use when working on figure morphs.
Possible problem with measuring wall is if it was made for Poser and which version as it has changed its base unit a number of times.
