Saving pose controls?
grinch2901
I surfed around and figured out how to do ERC freeze and was able to create several pose controls for some common expressions that I dialed up. So far so good, they showed up where I wanted them (under Pose Controls -> Head -> Expressions) and worked perfectly. Great!
But I don't know how to save them for future use. I tried "save modified assets" which does the trick for morphs added but when I brought G3F back the controls were gone. Per the documentation it says to save as DSF Morph which as far as I can tell in Studio 4.8 isn't a thing. But I suppose save as Morph Asset might do it, the thing is I want to do several such items, do they all need to be saved individually? If you save as morph asset, does it still remain a pose control under the pose controls? The documentation leave much to the imagination. Any help is appreciated!
Yes, moprh asset is what you want - modified assets will save only existing assets that have been modified, you need to do the Morph Asset save to set the options initially.
