Putting shoes on
Need help with some shoes.  I bought a pair of high heels from Renderosity, and I can't seem to fit them on my model.  I am 100% sure the shoes are for Genesis 3 Female and that's the model I'm using.  Is there a trick to putting them on?  They have a "1-click" styles.. Ive tried everything.. They're showing up in my conent Library, and I'm pretty sure I loaded them correclty..
  • LeanaLeana Posts: 13,641
    What shoes are those, and how are they not working? Are you sure you're loading the shoes and not only a material for them?
  • I have a slightly diferent problem with shoes, in fact all shoes and boots with 1 click style, i just don't seam to be able to change the style from the default.
    They load propley change colors proply and render perfectly. But i canot change the heel or platform style to the others in the libary.
    I select the actor, apply the foot pose, select the shoe and apply, perfect, but when i apply the the style to Sexy pump V7 nothing?
    What am i missing or have i gone totally blonde.
    Andrea
  • Which shoes?
  • waltn3mtjwaltn3mtj Posts: 112
    Are you selecting the model first? If the shoes show up by themselves - say, like cameras and lights, they don't want to work correctly by my experience. When The model is selected first, they should fit to her better. When you click the model after selecting (installing) the shoes, they should show up under her name as a part of her, just like her hair and all should.
    There are some I've found, that even come with a bundle (the big Victoria 6 and 7 bundles for example) that just don't want to fit 100%. I've found that playing with body shape helps some, too, if you aren't looking for a particular shape. However.....that has made some dresses, skirts, etc not want to render properly.......
