connecting two subsets to make a larger scene.
lstubbs2lstubbs2 Posts: 51
Still a bit noobish here....but for the lide of me...I can't figure out how to connect two subsets to make a larger scene..
I've found [] loads about subsets...but never any discussion on how to connect them end to end.
Can anyone shed some light on this for me....Thank you.
  • felisfelis Posts: 6,656
    If you load a subset it will just load into the existing scene.
  • crosswindcrosswind Posts: 10,358
    edited December 2023
    With an empty scene,  Ctrl + Select multiple Scene Subsets, RMB click menu - Merge Into Scene...
    Tweak coordinates of subsets as needed, then save the merged scene as Scene file or another Scene Subset as you wish.
    496 x 1302 - 78K
    Post edited by crosswind on
  • If you just diuble-click a subset in a content pane it will merge. Juast be aware that is both subsets have settings nodes (e.g. Environment Settings) the last one loaded will apply.
  • I can get the subsets merged.....I can even copy and paste entire key segments....
    I assume when the subsets merge...you are supposed to transfer keys from say....Cassie 2's timeline to Cassie 1's timeline...Creating One Cassie with all the keys.....
    Maybe I'm wrong....again...still noobish.
    Merging animated range(s) on Timeline from one figure to another is totally different from "connecting two subsets to make a larger scene"...
    Save Cassie2's animated range as a Pose Preset, select Cassie1, Skip to Play Range End or increase Total Frames as needed, load the saved Pose Preset of Cassie2.
    If Cassie1 and Cassie2 are in the same scene, copy / paste keyframes.
