Do you need to install Face Transfer 2?
I just bought Face Transfer 2 and it didn't show up on my DIM. Does it install another way or is there a glitch with DIM. I did check my account and saw it was purchased. Any ideas?
  • crosswindcrosswind Posts: 10,351
    FT2 plug-in is provided in DS 4.22.0.15 General Release and Public Build 4.22.1.41. Pls make sure you've updated DS application first.
    Then launch DS, go to  menu : Help - About Installed Plugin, you'll find FT2. Enter the serial number, restart DS.
    All I know is I have 4.22 version. I don't know how to find the number after 22. But since there's no update waiting in DIM, I assume I have the lastest version. I don't know what the Public Build is. Never heard of it before.
    As for your second sentence, I have never seen that proceedure before. But I did it. Nothing happened. I restarted Daz, checked that list again and the little plug next to the name is yellow. Don't know what that means (see image). Face Transfer 2 isn't listed under windows>panes. What's missing? Did I miss a proceedure?
    1920 x 1080 - 336K
    1. Public Build is the beta version of DS, which includes latest new features and the fix of bugs.
    2. For any plugin that you bought has a serial number, you need to go for the procedure of "registration".
    3. As for the yellow icon, you have to retry a restart of DS. Wait for a while before you relaunch DS. Then the icon should turn to green.
    4. There's no separate Face Transfer 2 menu item under Windows - Panes... it's still labeled as Face Transfer in which FT1 and FT2 are embedded together.
  • Step 4. Thanks, I guess Daz doesn't want it to be easy. They just could have added the '2' and avoid confusion. I'll try the reboot again and see what happens. Thanks again for the great help.
    Yep ! Good luck !
    Having two separate panes that do the same job in the same way would not seem easier than having one that adapts as needed.
  • Help>About Daz Studio will give the full version.
  • I have version 4.22.0.15. I still dont see in installed plugins and I bought face transfer 2. I can't find to enter serial and I'm logged Daz3d Pro serial is added. I read everything above and still nothing. I bought the first one and don't see in my serial list lol Do I have to buy Face Transfer 1 Unlimited again?
  • need help I installed it, the plugin appears enabled, but it doesn't show up in the window for me to use.
    276 x 59 - 5K
    315 x 920 - 106K
  • Richard HaseltineRichard Haseltine Posts: 111,937
    edited November 2025
    Did you restart Daz Studio after entering the serial number? It will appear as Face Transfer once it is active, there is only one pane shared by both of them.
