i lost my dress in Daz studio 4.9......
when i am in 4.8 i got a Gown2 dress and when i use 4.9 it gone.......
what is the update of 4.9?.....
also when i download freebie of the week sometimes it did not appare in the thing....how come?
(that will make me scare about buying stuff in the shop....)
  • Zev0Zev0 Posts: 7,123
    edited November 2015
    This version of 4.9 has fitting issues and its being addressed. Was working in the previous beta. Looks like when you open a saved scene all hell breaks loose in some cases. I had a guy with floating body hair that refused to fit on the figure. Then when I opened that scene in 4.8 all was fine again.
    Post edited by Zev0 on
  • kyoto kidkyoto kid Posts: 42,408
    ...hmmm, maybe it's good I haven't been able to download the beta (no Net connection to the Workstation).
    Post edited by kyoto kid on
  • Oso3DOso3D Posts: 15,116
    It's really making me grit my teeth because there's a bug in 4.8 that causes a bunch of stuff to crash, and then that bug that causes a lot of clothing I use not to fit right in 4.9.
    Sooo.... yeah.
    Sooo.... yeah.
    Yeah...but 4.9 is still a beta, so those kind of things are to be expected.
    Sooo.... yeah.
    Oh sure. I'm not mad at them or anything. Just chagrinned at trying to figure out what to do.
    (For the most part I'm just working around the 4.8 bug where possible, because it can be fixed by turning off metallicity on affected models, which isn't terribly bad. Replacing uniforms and other clothing, harder. ;)
  • Oh sure. I'm not mad at them or anything. Just chagrinned at trying to figure out what to do.
    Can you give me an example of how you might cause the crash? I dont have alot of crashes with 4.8, very rarely.
    It's an Iray specific bug...certain combinations in the Iray materials will cause a crash, because of a bug in the Iray version in 4.8.   That bug is fixed in the version of Iray in 4.9 (yes, the fix had to come from Nvidia/Iray).  But, right now there's a number of bugs in the beta, that if you are doing production work or need a pretty stable, consistent environment, it can't be assured.
  • so i am like haing a lot of model that which is not working
    if i use older version they will be back?
    WSpecifically how aren't they working?
    If it is the fit-to problem, then yes.  If it is items not found...maybe.
    AnotherUserName: The two cases I've run into are the http://www.daz3d.com/marcoor-fg-c4 and http://www.daz3d.com/dystopian-worker-drone
    With Iray shaders and Metallicity > 0, crash on render (or Nvidia preview)
    Which is a problem since several of the major characters in my webcomic are Dystopian Worker Drones. Though setting metallicity to 0 has been ok.
    yes is file not find.....
    so which version i should use!!? (any good suggestion?)
    If it's not found, make sure that the beta is using the same content mapping as the previous version (Edit > Preferences > Content Library > Content Directory Manager).  Or if you have installed content with Connect, it's possible that it could be a problem with the Connect file structure...in which case you'll need to file a bug report (the Contact Us link at the bottom of this page will lead you to where to file the bug report).
  • nicsttnicstt Posts: 11,715
    To the OP; not sure if you've noticed, but it's normal for there to be only underwear and swimwear (of the skimpy variety) so Daz is merely correcting a bug that allows normal clothes. laugh
