Claudia Hair for Genesis 8 fatal error
arsafonarsafon Posts: 5
Hello everybody!
Every time I launch Iray an error window appears. Can anyone suggest how to solve this problem?
Post edited by arsafon on
  • memcneil70memcneil70 Posts: 6,094
    Did you mean https://www.daz3d.com/claudia-hair-for-genesis-3-and-8-females ?
    If so, check references to OOT hair color issues, verify you have the most recent version of Nvidia drivers and you are up to date on the hair and its textures. There was an issue the PA is addressing with updates, but you may need to research that for more details than I remember at this time. It came because of Nvidia, not something the PA did. Also check your version of Daz Studio.
    While I have a variety of set-ups, there is one hair I can't even install on my MacBookPro M1 because it crashes D|S immediately. So I uninstalled it. My Window computers have no issue.
    Also check the Scene Info tab for how many vertices the hair has and does your computer have enought RAM and VRam to handle it.
    These are a few things I can think of off the top of my head.
    Mary
  • crosswindcrosswind Posts: 10,249
    edited December 2023
    Check the Resolve Issues in here - http://docs.daz3d.com/doku.php/public/read_me/index/56911/start
    Quite a lot of people encountered this issue  with DS ver. 4.22... Updating the product will fix it.
    Post edited by crosswind on
  • Thanks for answers, but nothing help - i install new drivers from Nvidia and Daz 4.22. Also couple other's hairs from "outoftouch" now have same issue (some hairs work fine some get fatal error even they work fine before).
    https://www.daz3d.com/forums/discussion/656961/4-22-crashes-when-rendering/p2
    Make sure you don't have any copy of old OOT hair blending shader in other library / Daz Connect, clear DSON cache, correctly update the product. It'll work.
  • I changed my hair color and it worked well, I used this https://www.daz3d.com/colorwerks-hair-shaders-for-iray
