How to zero "Pose Controls" but keep "Transforms"?
Hello, I usualy use pose controls to setup pose. In some situations, I need to convert it to transforms only (zero "Pose Controls" but keep "Transforms"). I tryied  the following but with half result:
I loaded Genesis 3 Male and set "Arms Up-Down" and "Legs Out" pose controls.
I saved as "Pose Preset...". During saving I used "Check All Modified Only" and after that I uncheck all "Pose Controls".
When I use the saved pose the legs are set but the hands stay at default position.
Any suggestion? Thank you.
  • crosswindcrosswind Posts: 10,248
    Did you "Bake to Transforms" before saving Pose Preset ? If not, you need to do that beforehand...
    The reason why you still got "Legs Out" is that there're Alias properties of "Legs Out" under figure's Pelvis node while "Arms Up-Down" doesn't have any Alias. If you just uncheck Pose Controls, you'll still get "Legs Out" but lose "Arms Up-Down" ~~
    686 x 805 - 55K
  • Michal P.Michal P. Posts: 95
    edited December 2023
    Thank you for the help.
    For those who cannot find "Bake to Transforms": go to Parameters tab and use the small icon with triangle and four lines. Menu with "Bake to Transforms" will appear.
    If you have animation, it will do it for whole animation. Go to frame 0 before doing "Bake to Transforms".
    Post edited by Michal P. on
